I'm looking at trying to add a geolocated image to a map using the JS API 4.x that works in both 2d and 3d. Previously we only needed 2d and used a BaseDynamicLayer subclass to accomplish the task, however we are now working on implementing 3d to the map and need the image to display there as well. Currently the BaseDynamicLayer is not supported in 3d and I was unable to find a suitable replacement which did what we needed in both 2d and 3d.
I've tried to implement other layer types and was unable to get them to work. Is there a specific layer type I should direct my attention to or any plans to support the BaseDynamicLayer in 3d in the near future.
EDIT:
I realize I didn't include this in the original post but the image used is actually a string (data:image/png;base64,...) and the following is the subclass created to add it to the map
const CustomImageOverlay = BaseDynamicLayer.createSubclass({
getImageUrl() {
// Create a canvas DOM element and set its width and height to be the same as the picture
if (!this.canvas) {
this.canvas = document.createElement('canvas')
this.canvas.width = newImage.width;
this.canvas.height = newImage.height;
// The geographic coordinates of the upper left corner are converted to screen coordinates,
// in order to obtain the starting point of the canvas drawing picture
const upperLeftMapPoint = {
x: xmin,
y: ymax,
spatialReference
const upperLeftScreenPoint = mapView.toScreen(upperLeftMapPoint);
//Calculate the width and height of the canvas drawn picture according to the extent range
//Lower left corner
const lowerLeftMapPoint = {
x: xmin,
y: ymin,
spatialReference
const lowerLeftScreenPoint = mapView.toScreen(lowerLeftMapPoint);
//Upper right corner
const upperRightMapPoint = {
x: xmax,
y: ymax,
spatialReference
const upperRightScreenPoint = mapView.toScreen(upperRightMapPoint);
this.canvas.getContext('2d').drawImage(
newImage,
upperLeftScreenPoint.x,
upperLeftScreenPoint.y,
Math.abs(upperRightScreenPoint.x - lowerLeftScreenPoint.x),
Math.abs(upperRightScreenPoint.y - lowerLeftScreenPoint.y)
return this.canvas;
fetchImage(){
const canvas = this.getImageUrl();
return canvas;
});newImage is the string, and xmin, xmax, ymin, ymax are all defined previously based on location.
I know canvas.getContext('2d').drawImage() renders a 2d image and could be the reason this doesn't work but I haven't found a way to actually get it work (in either 2D or 3D) trying a different approach with the subclass methods or with any other layer within the Esri API.
Any advice or tips would be greatly appreciated
Thank You
