Hi there,
We're currently using Field Maps as a replacement for Collector on Enterprise 10.7 and are about to make the jump to 10.9.1 which will have Field Maps native to the Enterprise environment.
I'm currently (indeed have been for several years now) deciding between Survey123 vs Field Maps smart forms. Our primary use is regulatory compliance documentation. While discussing the complexity of the forms in deciding between the two options has merit (particularly in UI/UX), data storage is my primary concern.
When a form is authored in Field Maps, it appears that it is an object associated with the 'map' itself. Where are these forms written to? Do they exist as objects within the data store? Can they be transferred to an ECM outside the Esri ecosystem?
Thanks in advance!
