I'm doing an integration using ArcGIS Javascript and trying to host this in a Linux environment. So I can use the proxy code done using ASP.net as it will work only on Windows IIS.
Can someone help me of getting this authentication issue solved related to Linux? Any other option for authentication would be fine too.
I saw some links related to token generation for authentication. If someone can brief me on what needed to be done on that is also fine.
