Hi all,
I've just created a feature layer (infrastructure) and related table (inspections) to use with ArcGIS apps. I used Map viewer classic in ArcGIS Online to do this as I don't think it's yet possible in the new map viewer. I have created an online and an offline version of the map for my team.
In Field Maps on Android, I am able to view the associated records for a given feature successfully, however when I try to add a new inspection to the related table on an offline map, the form which comes up is blank - the fields I need to populate are missing, so I can't actually add any information anywhere. It seems to be fine with the online version. If I open the same map up in Collector and try to make an inspection, the form comes up correctly with the offline maps and I am able to populate the fields and submit new records successfully, which makes me think there is perhaps a bug?
Jen
