I've run into a small issue in my application and am wondering if someone has already solved it. We're currently using feature reduction clusters and displaying labels on those clusters using an arcade expression.
The expression looks like
labelExpressionInfo: {
expression: `
var count = $feature.cluster_count*$feature.cluster_avg_totalAssets
Text(count, '#,### ')
}We are trying to achieve rounding within the expression. I know that I can write custom code to handle conditions of the count, but I'm wondering if there is a better way to achieve the visualization shown below where numbers above 1000 round to the nearest hundred and numbers above 100,000 round to the nearest thousand and numbers above 1000000 round to the nearest million.
Is the best path here just to write code to handle each situation?
https://developers.arcgis.com/javascript/latest/sample-code/featurereduction-cluster-filter/
