Hi All,
I'm getting some strange behavior in my HA ArcGIS Enterprise on AWS. It taken to long (21 seconds) to generate a token through a python code, it's the code:
import time
import requests
import json
def generate_token():
start_time = time.time()
payload = { 'username': 'usuario', 'password': 'SECRET', 'referer': 'https://SITE.com.br/portal/portaladmin', 'f': 'json' }
r = requests.post('https://SITE.com.br/portal/sharing/rest/generateToken', data=payload)
response = json.loads(r.text)
token = response['token']
print("--- %s segundos ---" % (time.time() - start_time))
return token
print(generate_token())
When I run this code at my staging environment without ELB the code works very well and token is generated quickly.
Does someone had faced this issue?
Or any tip
My environment is 10.8.1
Thanks and Regards,
Wellington
