Hi
I've recently discovered that i can use LAS files from my drone mapping software in ArcGIS Pro. I have been using the LAS point statistics as raster tool from Data management tools to convert the LAS to a raster which further through the process allows me to extract point data using select by attributes and then export. It seems that the layer that is created with the LAS point statistics tool somehow calculates/creates some sort of ground level being 0 and then gives me values for everything above that which is great cause the LAS height values were between 15 and 25 metres when they come out of the mapping software, not so easy for me to use. Allows me to quickly calculate tree heights for example,
So I would like to be able to achieve the same result when adding a dsm raster to a project but i cant seem to find the right tool that gives a similar result to the LAS point statistics tool regarding the 0 height value and everything above that.
Does anyone know if there is a tool for this?
ArcGIS Pro 2.8.2
