I am using ArcGIS Pro, version 2.6.0
I have problem with summarize elevation tool. I have three datasets and two of them worked without problem, just with the third I´ve got error messages:
File "Y:\Tools\Elevation\scripts\sumelevation.py", line 621, in execute
in_mem_out = self.computePointStats(tempOut, feature_id_field, dem_resolution, "all", feat_desc.ShapeType, feat_count, inputExt)
File "Y:\Tools\Elevation\scripts\sumelevation.py", line 318, in computePointStats
arcpy.CalculateField_management(zone_features, "MinElevation", "CalcVal(!SHAPE!, '{0}')".format(dem_layer_elevation), "PYTHON", calcValFunction)
File "c:\program files\arcgis\server\arcpy\arcpy\management.py", line 3647, in CalculateField
raise e
ExecuteError: ERROR 000539: Error running expression: CalcVal(GPVARIANTOBJECT0, 'D_24m_sumelev')
File "<expression>", line 1, in <module>
File "<string>", line 5, in CalcVal
File "c:\program files\arcgis\server\arcpy\arcpy\management.py", line 17279, in GetCellValue
raise e
ExecuteError: ERROR 000622: Failed to execute (Get Cell Value). Parameters are not valid.
ERROR 000628: Cannot set input into parameter location_point.
Failed to execute (CalculateField).
Failed to execute (SummarizeElevation).
Failed.
Does anyone know what to do with this? I checked the data set and everything is in the same format as the previous two datasets that worked well..
Thank you very much
Thank you very much
