Follow-up to this question Solved: Re: Relating Table A to Table D via Tables B and C - Esri Community
I got the expression working great, but it when it tries to return a field with hyperlinks E.g.
<a href="C:\Users\USER\Documents\ArcGIS\Projects\testing\Documents_testing\Lorem Ipsum.docx" target=_top">Lorem Ipsum.docx</a>
it returns a blank.
I looked into it and found this post, but I've had a lot of trouble implementing it.
I've tried making a new field with just the blank file path, then adding the html formatting to the final bit that's pushed , but that doesn't return anything either.
var docs = []
for(var a in filtered_a) {
Push(docs, "<a href="'+a.File_Path+'"</a>")
Is there a way to have the expression return hyperlinks?
Thanks!
