Portal 10.6.1
Map Service published to federated portal - published from ArcMap (can utilise Pro)
Hi All,
I'm currently having a headache as to how to add a new dataset to an existing service (dataset to be added to an existing group layer in the service) and have it update in the Web Map without having to remove the service, re-add it and then reconfigure all of the popups, aliases, popup display formatting etc previously configured in the Web Map. This is compounded by the fact that the service is used in multiple Web Maps.
Messing about with the Web Map JSON is a possibility, but not one I'm particularly fond of. Also would switching to Pro for all publishing solve any issues and allow the full necessary configuration of the Web Map?
Many thanks for any input.
