I have written an SOI for rights management in c# and let it run on ArcGIS server 10.7.1.
Normally it is working good, but sometimes the Service becomes unavailable. In the Log files I find the message:
<Msg time="2021-05-31T10:13:27,277" type="SEVERE" code="9000" source="Rest" process="4724" thread="1" methodName="" machine="MU-KARTENSRV.REGIONHANNOVER.DE" user="" elapsed="" requestID="feed7716-61c9-4107-ad25-5133bfcc1d58">Error performing query operation Error handling service request :0x80004003 - Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt. in 'GlobalNetXXSOI'</Msg>
The error message says, that there is a null pointer.
The translation of the germen massage should be:
"Object reference not set to an instance of an object"
I have a class attribute:
private IServerObject serverObject;
Like in the esri samples it is filled in the init method:
public void Init(IServerObjectHelper pSOH)
try
serverObject = pSOH.ServerObject;
catch (Exception e)
logger.LogError(e);
Logger.WriteSystemError(e.ToString());
But now it seems, that this attribute becomes null some times. Is there any way I could get the ServerObject, outside the Init method, so I could restore it, when it becomes null?
Best regards,
Andreas Ruloffs
