Hi
I have a problem with an older Compare analysis map.
Earlier the auto-sync function worked, but I had to update the maps and it doesn't function anymore. I can't just build the app again, because that would change the link and that is already shared and used.
If I load other maps to the left side, the sync function activates again, but not with that specific map I have to show there. I built up the map on the left side several times and tried to publish from ArcGIS 10.5 and Pro, but it didn't help.
Have anybody had symilar problem and found solution?
