I'm trying to print to pdf for a large paper size. Using the default print export is leaving lines on the aerial due to transparency.
I've used this feature with Desktop with an external print to pdf (Bullzip) and it's worked fine. But with Pro (v2.7.3), it's only printing a portion of the page, and the tiling option to 'Fit to paper size' is disabled. I've tried other print to pdf options, an older Pro version on a virtual desktop (v 2.5.1) and I can't figure it out.
Is there some reason this is disabled, or is there some setting I am not seeing?
Thank you in advance!
