G'day everyone,
I'm using ArcMap desktop 10.6.1. I'm need need of some help.
I have a dataset of .GPX points which I have converted to .Shp. I have overlaid this onto a DEM and satellite image. What I'm trying to get is information on the line (the line I produced from the .gpx data points) using the underlaid layers. Specifically; lengths, gradient, etc. I tried to use the geometry calculator but received an error message regarding the wrong projection (WGS but required PCS). Furthermore, is it possible to merge the information embedded in the DEM into the satellite imagery to have the satellite imagery? As you can tell I'm quite inexperienced but any advice would help. I've attached a screenshot.
