Dear all,
I tried to load this third party WMS (https://data.opendevelopmentmekong.net/geoserver/ODMekong/lao_admbnda_adm1_ngd_20191112/wms) with the following code: (find the full code at bottom of post)
let wmsLayer = new WMSLayer({
url: "https://data.opendevelopmentmekong.net/geoserver/ODMekong/lao_admbnda_adm1_ngd_20191112/wms"
map.add(wmsLayer);
The layer does not load and requests are answered with 404. In the networks tab I see that the WMS' url is changed, pointing now to https://developers.arcgis.com/ instead of the url where the geoserver is located (The code was ran from the sandbox. It seems it always takes the url of the current site).
Would I manually replace https://developers.arcgis.com from this request with the proper url where the geoserver is located (https://data.opendevelopmentmekong.net) I would get the right response.
The problem occurs only for some WMS, it works for example for https://ahocevar.com/geoserver/wms
Is it possible to load the former service with ESRI API 4 so that it points to the correct url? Or is there anything else I could do to fix the issue? I would be very thankful for support or hints.
(The code, running from JSAPI4 Sandbox)
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>WMSLayer - 4.19</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.19/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.19/"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/WMSLayer",
"esri/Basemap"
], function (Map, MapView, WMSLayer, Basemap) {
title: "WMS Layer",
url:
var map = new Map({
basemap: "streets-vector"
var mapView = new MapView({
map: map,
container: "viewDiv"
map.add(wmsLayer);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
