Good morning,
I'm having issues syncing an offline map in both Collector (20.2.2) and Field Maps (21.1.0) on a Samsung Galaxy SM-T540 running Android 10. The map is configured with related tables so users can document each inspection on a point feature. The map is configured for offline mode with sync enabled and all layers that feed into the map have sync enabled as well.
If the user makes any edit BESIDES editing an existing related table record, like updating point geometries, updating point attributes, or creating a new related table record, Collector and Field Maps sync fine. However, if a single edit is made to an existing related table record, the sync fails and the error log simply reads "Feature tiling disabled." I have tested this over multiple devices and narrowed it down to the editing of existing related table records only. This issue appears to be Android specific because I was able to edit an existing related table record and sync fine with an iPhone XR with Field Maps iOS 21.1.1 build 396.
I have resorted to manually syncing the data by copying over the mobile runtime geodatabase into Pro and syncing that way. However, even when I sync the data manually on the desktop, a sync error is given and the related table record edits do not sync. While I am attempting to resolve this error I have asked the users to simply create a new related table record each time instead of editing older records. This is more in line with the desired workflow anyways, but sometimes they forget in the field and one record edit makes the entire sync fail.
Has anyone here encountered the "Feature tiling disabled" error and if so, what helped you resolve it?
Thanks for any help you can offer!
