Need help with Operations Dashboard using Enterprise 10.7.1!
I published a map service with 50k records from our PostgreSQL database (version 10.9) to our ArcGIS Server (10.7.1). Then created a map of just this layer and tried to make an Operations Dashboard with a pie chart and the map. When I add the pie chart, I use this layer as the source and use the statistic of "count" based on the account type field which is text type. I want to be able to click on a piece of the pie and have it filter the map. However, in the Actions tab of the pie chart settings, it says "no elements supporting actions yet."
I am able to add Actions in the pie chart settings for other map services published from this database to the same server with no problem.
Any ideas?? Thanks in advance!
