We have a recent Enterprise deployment and are having difficulty when publishing a 3D scene with a multipatch layer from ArcGIS Pro 10.8.1. The publishing reports "success" and the scene is listed in the content section of our portal. However, upon opening the webscene, the basemap is visible and a message pops up that the "xyz layer could not be added". When attempting to add the layer manually via the URL, the same message appears.
On the other hand, ARC Catalog will preview the datasets published in the "Hosted" services section under the ArcGIS Server used. (The server is federated to our portal.)
This is a relatively small multipatch layer that was exported out from a dwg file as a featurelayer in a new geodatabase. The max record count is 2000.
Any ideas??
