I created a Field Map to collect date, 3 fields are typed manually and 3 fields are attribute expressions.
The atribute expressions fields are intersects between layers.
When i export for csv in a web map, the attribute expression results in "[object Promise]"
This image are the exported csv, the blue fields are typed manually and the yellow fields are attribute expression.
How i can make to export the correct values from the atrribute expression in csv?
