I am creating a GP tool, with a Python toolbox, that should return FeatureSets with symbology.
To simplify my process, I try the following, inspired by the FeatureSet documentation (https://pro.arcgis.com/en/pro-app/latest/arcpy/classes/featureset.htm). It is just a combination of example 1 and 2.
def execute(self, parameters, messages):
"""The source code of the tool."""
coordinates = [[-117.196717216, 34.046944853],
[-117.186226483, 34.046498438],
[-117.179530271, 34.038016569],
[-117.187454122, 34.039132605],
[-117.177744614, 34.056765964],
[-117.156205131, 34.064466609],
[-117.145491191, 34.068261129],
[-117.170825195, 34.073618099],
[-117.186784501, 34.068149525],
[-117.158325598, 34.03489167]]
# Create an in_memory feature class to initially contain the coordinate pairs
feature_class = arcpy.CreateFeatureclass_management(
"in_memory", "tempfc", "POINT")[0]
# Open an insert cursor
with arcpy.da.InsertCursor(feature_class, ["SHAPE@XY"]) as cursor:
# Iterate through list of coordinates and add to cursor
for (x, y) in coordinates:
cursor.insertRow([(x, y)])
renderer = '''{
"renderer": {
"type": "simple",
"symbol": {
"type": "esriSFS",
"style": "esriSFSSolid",
"color": [
255,
0,
0,
255
"outline": {
"type": "esriSLS",
"style": "esriSLSSolid",
"color": [
110,
110,
110,
255
"width": 2
"label": "",
"description": "",
"rotationType": "geographic",
"rotationExpression": ""
# Create empty FeatureSet
feature_set = arcpy.FeatureSet()
# Load data into FeatureSet with query
feature_set.load(feature_class, None, None, renderer, True)
parameters[2].value = feature_set
return
In the tool I have the following output parameter:
out_features = arcpy.Parameter(
displayName="Observationer",
name="Observationer",
datatype="DEFeatureClass",
#datatype="GPFeatureRecordSetLayer",
parameterType="Optional",
direction="Derived")
Until now I use datatype="DEFeatureClass" in stead of the more logical GPFeatureRecordSetLayer. Because the latter one will not return any records when I use that.
Returning using DEFeatureClass:
"paramName": "Observationer",
"dataType": "GPFeatureRecordSetLayer",
"value": {
"displayFieldName": "",
"geometryType": "esriGeometryPoint",
"spatialReference": {"wkid": null},
"fields": [{
"name": "OID",
"type": "esriFieldTypeOID",
"alias": "OID"
"features": [
"attributes": {"OID": 1},
"geometry": {
"x": -117.19671630859375,
"y": 34.046875
"attributes": {"OID": 2},
"geometry": {
"x": -117.18621826171875,
"y": 34.0465087890625
"exceededTransferLimit": false
}But no symbology/renderer
Using GPFeatureRecordSetLayer returns:
"value": {
"fields": [{
"name": "OID",
"alias": "OID"
"features": [],
}No features!!
When I read the following https://developers.arcgis.com/rest/services-reference/gp-data-types.htm#ESRI_SECTION2_8DE491EA13D843BF84C780B7CD5821A2 under the FeatureCollection output section, it is referring to a returnFeatureCollection setting which I cannot find any information about anywhere.
I hope someone has a clue of what to do.
The complete toolbox:
# -*- coding: utf-8 -*-
import arcpy
import os
class test_tool(object):
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "Test"
self.description = "Test"
self.canRunInBackground = False
def getParameterInfo(self):
"""Define parameter definitions"""
#Define parameter definitions
params = [out_features]
return params
def isLicensed(self):
"""Set whether tool is licensed to execute."""
return True
def updateParameters(self, parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
return
def updateMessages(self, parameters):
"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""
return
renderer = '''{
"renderer": {
"type": "simple",
"symbol": {
"type": "esriSFS",
"color": [
255,
0,
0,
255
"outline": {
"type": "esriSLS",
"color": [
110,
110,
110,
255
"width": 2
"label": "",
"description": "",
return
