Hi there,
I am trying to create xy event layer that display data from csv tables as points, set new projected system, copy features to shapefiles. I am new to Python, the script below is working BUT only for 1 file, the last one printed, and I don't know how to do that for all files in directory. Thank you.
import arcpy
import os
mydir = r"I:\gas\export\gps_test"
for filename in os.listdir(mydir):
if filename.endswith(".csv") or filename.endswith(".xlsx"):
print(os.path.join(mydir, filename))
else:
continue
# Set environment settings
arcpy.env.workspace = mydir
try:
# Set the local variables
in_table = filename
out_layer = "gps_" + filename
saved_layer = mydir
x_coords = "Easting"
y_coords = "Northing"
z_coords = "Elevation"
# Set the spatial reference
spRef = arcpy.SpatialReference("NZGD 1949 Hawkes Bay Circuit")
# Make the XY event layer
arcpy.MakeXYEventLayer_management(in_table, x_coords, y_coords, out_layer, spRef, z_coords)
# Print the total rows
print(arcpy.GetCount_management(out_layer))
# Save to a layer file
arcpy.SaveToLayerFile_management(out_layer, saved_layer)
# Copy features to shapefile
arcpy.CopyFeatures_management(out_layer, out_layer.strip(".shp"))
except Exception as err:
print(err.args[0])
