I know 2.7 had the "dropping" lines and other graphics during export issue, and that is fixed in 2.7.1. However now i am experiencing another exporting issue with 2.7.1 using Map series.
I like many Pro users import a ArcMap document into pro. it comes in and i make the necessary changes i need to the map and get it ready for production/export. Then i export the pdf with the Share>Layout buttons, this map in particular is a 12 page map series.
The export begins and it hangs on "Export in Progress 1/12", it never switches from that, however the PDF gets created just fine. The frustrating part is that Pro just hangs there and i can do anything with it. I can cancel the export, i can't save the project and move on to another layout or map within the same project. I have to use the task manager to "End Task" and then re-open the project to do more work.
Has anyone run into similar problems? Do you have any solutions? This is really disruptive to my workflows and causes me many saving headaches and exporting problems.
