I'm using ArcMap 10.1 and I'm trying to make contour lines from a DEM. I've made 1m contour lines which are fine, but I want contour lines every 10cm. I was able to make them, but they are clumped together every meter. So the 8.9m contour is half way between the 9m and 8m contour and the 8.8m-8.1 are squeezed between the 8.9m and 8m lines. If that doesn't make sense I've attached a picture showing this.
How can I make it so they are evenly spread out? The data I have isn't this precise so I know this is just an estimation, but it still seems strange that the lines are clumping together. Any thoughts?
David
