A few points to improve on the average function in Field Maps:
> Point averaging is hidden very far away in the settings. It would be much more convenient if you could adjust this during data collection.
> More averaging variants can greatly improve the use of averaging. Now it goes with a time interval. For many situations where an (unreachable) center point has to be calculated, it would be more useful if you collect the points at a chosen location that need to be averaged instead of at a fixed time interval.
I can give an example when measuring tree locations. You can measure around the tree to calculate the center of the trunk base. Reception of GNSS signals is always poor under trees, so you often have to stand still longer to have a good fix solution. Each tree also has a different diameter, so the number of points to be averaged should differ per tree. Time interval resources will never work for this application.
Another application can be, for example, measuring the center of a road profile. measure the curbs on both sides and you end up in the middle of the road with your chosen average points.
