Hello
I am working with the QuickReport template. Today I added a Feature Service via the Settings and now when I run the app it will not get past the disclaimer page. I also have a web map that I am using for the Refine Location page with the Feature Service as one of the layers.
I get the following error:
TypeErrror: Cannot read property 'spatialReference' of null
I have included the screen shot of the error and the line(s) of code that the hyperlink links to if you click on it.
I checked the Feature Service and it seems to have a spatial reference. I also copied and pasted the Feature Service layer used in the 311 app demo and it works fine. When I open the two Feature Services side by side in different windows the only difference I see in my metadata compared the file that actually works is that my layer does not have a spatial reference under extent. Could this be the issue?
https://services6.arcgis.com/TRp7qJKKVWTcWaHY/arcgis/rest/services/Arborglyph_Locations/FeatureServer/0
If so, how do you add an extent to the layer. I have done it to the Feature Service.
