When trying to create new web app I can preview a template fine but when trying to create it just hangs with the following
The following is the console output (Chrome)
TypeError: Cannot read property 'small' of undefined
at eval (/portal/home/webmap/js/esri/dijit/Configure.js:323)
at Array.reduce (<anonymous>)
at Object._getSharedValue (/portal/home/webmap/js/esri/dijit/Configure.js:322)
at Object.eval (/portal/home/webmap/js/esri/dijit/Configure.js:314)
at jsapi:64
at Array.forEach (<anonymous>)
at Object.eval (/portal/home/webmap/js/esri/dijit/Configure.js:308)
at jsapi:64
at Object._updateSharedValue (/portal/home/webmap/js/esri/dijit/Configure.js:307) "TypeError: Cannot read property 'small' of undefined
at eval (/portal/home/webmap/js/esri/dijit/Configure.js:323:19)
at Object._getSharedValue (/portal/home/webmap/js/esri/dijit/Configure.js:322:58)
at Object.eval (/portal/home/webmap/js/esri/dijit/Configure.js:314:18)
at /portal/jsapi/jsapi:64:337
at Object.eval (/portal/home/webmap/js/esri/dijit/Configure.js:308:24)
at Object._updateSharedValue (/portal/home/webmap/js/esri/dijit/Configure.js:307:36)"
l @ jsapi:115
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/wrappers/ItemBrowser.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Component.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Dropdowns/AccordionDropdown/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Loaders/LoaderBars.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Filters/CategoriesFilter/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Navigation/TabNav.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Modals/MobileWrap.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Dropdowns/Ago2018Dropdown.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Filters/MapAreaFilter.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Dropdowns/BasicDropdown.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Buttons/ToggleSwitch.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/DateSelection/DateRangeSelector/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/DateSelection/DatePicker.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Dropdowns/SortDropdown/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Navigation/Pager/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Filters/CreatedFilter/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Filters/ItemTypeFilter/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Buttons/Toggle.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Buttons/SvgButton.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Dropdowns/TextOptionDropdown.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Modals/Overlay.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Buttons/IconButton.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/ItemBrowser/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Filters/ModifiedFilter/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Filters/SharedFilter/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Filters/StatusFilter/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Filters/FolderFilter/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Filters/GroupFilter/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Buttons/CheckToggle.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Filters/TagsFilter/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Filters/CollaborationFilter/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Dropdowns/FilterController/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/ItemCards/AnalysisCard/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Buttons/FilterChip/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Management/LazyLoader.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Badges/Authoritative.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Loaders/LoaderIcon.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Badges/Badge.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Badges/Collaboration.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Badges/Marketplace.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Badges/Subscriber.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Badges/LivingAtlas.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/ItemCards/MiniCard/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Badges/Deprecated.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Badges/Premium.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/Badges/OpenData.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/js/arcgis-components/dist/ItemCards/MiniCardRow/index.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load SourceMap: Could not load content for /portal/home/webmap/js/esri/dijit/css/configure.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
Has anyone else experienced this and if so, how to resolve?
Thanks in advance,
Mark
