I am building a large terrain dataset (roughly 2000 square miles) in ArcGIS Pro and need some advice on how to speed things up. I've ran through this article on Fundamentals of Building Large Terrains.
The terrain will have 6 pyramid levels and span two counties so I've divided my multipoints into quadrants. My plan is to build the first terrain, the append the next set of multipoints and rebuild. Then continue this till all the multipoints have been incorporated into the terrain. I started the first process and the speed of the Build Terrain tool is going extremely slow. Looks like it will take multiple weeks to build one quadrant. I have 64GB ram available on my machine but Pro is only using about 3.
Anything I can do to speed up the process?
Given an unlimited budget (just an example here) , can someone give a basic breakdown of what ideal specs a computer should have for building a large terrain? My IT guys mentioned they can create a VM with beefed up specs or possibly purchase a machine strictly for terrain processing. I'd like to give them some 'best case' scenarios and work from there.
Thanks!
