private function showLocation(data:Object):void { hideInfoWindow(); graphicsLayer.clear(); var ptGraphic:Graphic = new Graphic(); ptGraphic.geometry = data.point; graphicsLayer.add(ptGraphic); var contentNavigator:ContentNavigator = new ContentNavigator(); // //Here is where you need to use a querytask to get the layers graphic that you want the popup to appear for // then after the async result from the query returns. // then you set that graphic in the contentNavigator.dataProvider // contentNavigator.dataProvider = new ArrayList([ resultGraphic ]); // Put the ContentNavigator in the info window. map.infoWindowContent = contentNavigator; if (map.scale > zoomScale) { map.scale = zoomScale; } map.centerAt(data.point); map.infoWindow.show(ptGraphic); }
