On occasion you may encounter circular arcs in your ArcMap Parcel Fabric that have geometry that becomes reversed when it is joined into the fabric. The original cause of the problem has been addressed in 10.6.1. The video will be useful if you have data with curves like that this that were created in releases prior to 10.6.1. The workarounds presented also work for fixing these curve while using earlier releases of the software, back to 10.4. This problem occurs for circular arcs that have deltas \ central angles close to 180°. The COGO attributes for the circular arc are
