Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Enterprise
ArcGIS Enterprise Ideeën
map.getLevel() should return absolute level, not relative level
JeffPace1
In the Javascript API (at leasst) map.getLevel() returns a relative level. For example, if your absemap contains levels 0-18 (i.e google or bing ) and you specify LODS in your map creation of levels 9-18, zooming to level 10 will return map.getLevel() = 1 (it is the second level in the map). This is very counterintinutive and does not work well for intergrating with other maps.
I would suggest map.getLevel() with optional parameter type: absolute or relative, with absolute as the default.
Vind meer berichten getagd met
Status: Openen
Reacties
SiqiLi
Tested with Flex API and its Map.Level() method also returns a relative level ID, which is 1.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
