We need a way to automatically disable extentions at ArcGIS Desktop start-up to prevent users from checking out extensions when they do not need them.
Hello.
I admit I am not impartial, but as this question has been raised here and on
Auto UnCheck Extensions
I feel free to promote our solution to the problem.
OpenLM provides the means to
1. Turn off licensed extensions on shut-down
2. Release idle extension licenses
3. Set license usage level per user/workstation.
Each of these approaches will accommodate the need you have expressed here.
Please observe this end of this document, (which I will shortly revise).
All the best,
Ori Kaplan
OpenLM - License Management
Provide functionality that disables concurrent extension license when ArcGIS Pro application is closed rather than extension automatically added , once ArcGIS Pro is opened for a new session can choose to enable extension if needed. (ENH-000146574)
Thanks for proposing Jerv. This will be useful for organisations who use concurrent licenses and extensions, when people assign an extension to their Pro and forgot to release it, the extension will always bind with this machine whenever the ArcGIS Pro is running. It cause troubles when extensions are in high demand use.
As some other applications has the idea to get maximum time of token usage (like AWS), hope ESRI can develop ‘permanently release extension when Pro is closed until manually assign extension again’ function.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
