Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Pro
ArcGIS Pro Ideas
Make newly added layers Not Selectable
Bragi_MárBragason
By default, when you install ArcMap, newly added layers are visible. You can make newly added layer non visible through ArcMap Options (General Tab in Customize ArcMap).
It would be nice to have an option similar to this to make newly added layers non selectable. I frequently add and remove layers while editing and almost always forget to make the new layer(s) not selectable, meaning that when added, the next time I mean to select a feature, I have to unselect all, remove the new layer(s) from the selectable layers list, and select the feature again.
Vind meer berichten getagd met
Map Exploration
Status: Openen
Reacties
ElizabethB
I agree! We have several layers in the same dataset in sde, and users here often forget to make the 'background' layer not selectable...I spend too much time cleaning up disconnected lines or overlapping polygons.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
