Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Pro
ArcGIS Pro Ideas
Query in ArcMap from a map service
JulieBrown
Give the ability to query by location (get geometry) using an ArcGIS Server map service. First off your map service has to be a feature service to allow this functionality - secondly you have to make a local copy for editing! I don't want to edit - just be able to use the service to do a select by location with other data in my map document. When you enable Feature Access on your map service it gives you 2 options to check - Editing and Querying - if i only choose Query then i shouldn't have to make a local copy for editing - should I?
Vind meer berichten getagd met
Status: Openen
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
