Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Pro
ArcGIS Pro Ideas
Dynamic Fields for Shape Features and Statistics
JayHalligan1
Dynamic fields that calculate on-the-fly for formulas, shape attributes, statistics, summaries
Examples
Formulas - Multiple field calculations like excel
(already mentioned in another post)
Shape Features - Areas, Lengths, etc.
Statistics - sum, avg, mean, etc
Summaries - Point Count within features
Essentially whenever a features is changes, the field automatically updates
Biggest help would be a summaries field where relates can be summarized in a field or points that fall within a polygon can be calculated without creating new files and will update as soon as new data is created.
Vind meer berichten getagd met
Status: Openen
Reacties
Hornbydd
jhalligan
If your data is in a GeoDatabase then the this maintains several shape features attributes as dynamic fields.
I don't understand your statistics field idea you only have 1 row per feature?
Dynamic field calculations where you set some sort of formula would be a good addition to ArcGIS.
AlexMahrou4
This is a common built-in function to any RDBMS, why can't we just make this happen?
ChrisHills
This is a great idea. I would really like to be able to create dynamic fields for when the source dataset is read-only and I do not want to create a local copy which would be a point-in-time snapshot and would quickly become out of data as the source data is changed.
RichardFairhurst
Most of these behaviors can be done by Attribute Assistant in real time during editing in an edit session on a shapefile, feature class or table. They can be set up in the
Dynamic Value table
to occur in response to feature creation, attribute updates, geometry updates, and/or manual triggering of a request to update all manual dynamic values (to prevent slow editing in cases where data that should only update after a series of features are created or edited, not as each feature is created or edited).
Field calculations within a single record is possible with the
EXPRESSION
method, which is the most flexible Attribute Assistant method. It can concatenate field values and strings and do other string manipulations like changing case (anything VB Script can do), process math equations, set date stamps, do conditional expressions, etc
LATITUDE
LOGNITUDE
X_COORDINATE
, and
Y_COORDINATE
all can auto update centroid locations of point line and polygons, and start and end locations of lines in response to feature geometry creation or changes.
LENGTH
can be updated for line features; however, area and perimiters of polygons is not supported, although that should be a simple enhancement.
Summary statistics with intersecting features is possible with the
INTERSECT_STATS method
. This could do a count of features if you autopopulated all points, lines or polygons with a field that always containeed the number 1 (Default value or Expression) and did a Sum with intersecting features.
Summary Statistics across all records in a feature class or table is possible with the
FEATURE_STATS method
. Unfortunately, it cannot do summaries based on a unique case field. However, although I do not do this in real time, Python cursors and dictionaries can do this without generating a separate statistics table and outperform Summary Statistics, Join and a Field Calculation. See my post on
Turbo Charging Data Manipulation with Python Cursors and Dictionaries
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
