Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Online
Add multiple layers discovered from ArcGIS Open Data into the same web map
AlexChiu
It would be useful if you could select multiple datasets from ArcGIS Open Data and add it into a webmap to compare datasets.
At the moment, you can only add one layer into a web map, if you need to add more layers you need to save the web map, then search for more layers via "Add > Search for" . There is no way to add in additional datasets to the same webmap via the an ArcGIS Open Data Portal.
Implementing this would allow for a much more streamlined workflow.
Vind meer berichten getagd met
Under Consideration
Status: Under Consideration
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
