Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Enterprise
ArcGIS Enterprise Ideeën
View dependent services
MikeSchonlau
It would be very helpful if there was a tool that would tell me which ArcGIS Server services are currently accessing a specific feature class. When I need to make a schema change, I end up having to stop all of my services to do it.
Vind meer berichten getagd met
Under Consideration
Status: Under Consideration
Reacties
NeillJobe
Our Admin Tools for ArcGIS Online (Pro) & Portal will show you item dependencies in this fashion. You can even print out the hierarchy so that you can reference it later. Here is a video that gives you a very quick run down -
https://youtu.be/S1CvjZrWn3M
Here is a link to the ArcGIS Marketplace -
https://marketplace.arcgis.com/listing.html?id=4b9205d08a42413085a17ca91b97e3c7
- See more at:
https://c.na9.visual.force.com/apex/ideaView?id=087E0000000Cxj0IAC#sthash.H8wk7gRz.dpuf
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
