Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Hoofdpagina
Producten
ArcGIS Online
Put the Remove item somewhere else on the layer properties menu
TimOrmsby
In ArcGIS Online, on the layer properties menu, the Remove choice should be in a different location on the menu, maybe within its own separators. As far as I know, you can’t undo this operation, which makes it kind of dangerous.
Being next to Rename on the menu makes it worse because renaming layers is so common. More than once I’ve changed symbology, changed pop-ups, and then removed a layer I meant to rename.
Vind meer berichten getagd met
Status: Openen
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
