Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Pro
ArcGIS Pro Ideas
IOAPI reader
CarolMcClellan
The Community Multiscale Air Quality Modelling System (CMAQ) is a suite of air quality modelling programs used worldwide to produce air quality model simulations.
In many cases, t
he output from the model is
in the format of a NetCDF3-based
"IOAPI" file
(hereafter, IOAPI file).
An IOAPI file stores its
spatial information in the file in a format
that
is not currently
supported by Esri’s NetCDF suite of tools, i.e. the IOAPI file spatial information does not following CF convention.
Because of this, ArcGIS as a visualization tool for Air Quality modelling results (such as mapping and animations) is not widely utilized and often abandoned in favour of open-source programs such as Verdi that can readily read-in model output files. The downfall of these open source programs is, however, that the data mapping are not as professional or customizable as ArcGIS allows, and the user is quite limited in what they can do to explore the data
and to produce information-rich maps.
It would be excellent if Esri could expand the NetCDF tools to accept IOAPI file inputs. I'm certain that if this was done, many more people in the Air Quality modelling community would leverage Esri software for their analysis and visualizations in lieu of the open source programs. ArcGIS is very powerful and capable of so many different things that are very relevant to this community that Esri needs to take some steps that will help to facilitate the use of their software by the users in this community.
Vind meer berichten getagd met
Status: Openen
Reacties
BenjaminLash
I use arcgis with ioapi regularly, the vast majority of the time actually. I would love a smoother interface. It's quite a bit of work to convert arcgis outputs to ioapi and vice versa, but necessary for regridding many different kinds of inputs (lat long grids vs meter grids, etc.)
AndreaFraser
We would like to use ArcGIS for file regridding and processing and would like a smoother interface.
this would allow us to incorporate out file into existing ArcGIS application and vise versa.
ScottSpak
This issue extends to many atmospheric science netCDF formats. More generally, the netCDF tools easily can and should support commonly used netCDF formats whose metadata contain all the projection, grid, and dimension information, which cannot currently be accessed through the multidimension tool interface. IOAPI, WRF, and ESMF would be a good start.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
