Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Pro
ArcGIS Pro Ideas
Modifications to Geodatabase Connection Properties panel
RicaSaporta
I am currenlty working in 10.1 and the new Connection Properties window is a bit awkward.
i suggest the following changes:
1 - put the "version" connection back into the Connection Properties window
- having then seperated is really adding time to the set up of a connection
- the seperation is also introducing a new step in the connection set up that is being missed by some users
2 - Bring back the "test connection" button to the interface
- this way you will have 3 choices at the bottom of the panel: Test Connection, OK (to connect), Cancel
- this will mean that a connection can be tested without forcing a connection to the data
- sometimes you only need to set up the credintials, not access the data
thank you
rica
Vind meer berichten getagd met
Geodatabase
Status: Openen
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
