Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Pro
ArcGIS Pro Ideas
Option of Using UNC Path for SDE Connection Files
MikeVolz
I have been working on a script to update SDE connection file information in mxd files. As part of this script I was using a UNC path to get to the updated SDE connection files. Although this created some temporary broken connections, it also showed promise in being able to have an enterprise GIS environment where the SDE connection information for mxds could be updated in the .sde connection files instead of in the mxds themselves. For my organization this would be the difference between updating 200 .sde files compared to over 200,000 SDE connections inside of mxds (that would be quite a big time and money savings).
I propose that ESRI provide the option of either embedding the SDE connection file information inside the mxds (as is currently done) or allowing this information to be brought into the mxd through the .sde connection files (available because of this bug, but incorporated into the base software).
Vind meer berichten getagd met
Status: Openen
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
