ArcGIS must use standard Windows roles!Create a domain with Coded ValuesCreate a feature class/table with a field Material and use this domain. Create some records, open attribute table and sort column Material with double click in header. The sort order is not in alphanumeric order! The sort order should be in alphanumeric instead of using the code!Auto adjust column width for column Material by double click in header between Material and Shape_Length. Standard for all Windows application are auto adjust to fit the contents, but not in ArcGIS!
I ran across this old post and figured I'd add a comment that both issues raised in the original description are addressed in ArcMap and ArcGIS Pro.
That is, sorting in ascending/descending order works when showing the codes, or when showing the descriptions. The sort honors whichever you are displaying in the table.
Double-clicking in the header between columns auto-adjusts the width.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
