I'm attempting to do a sidewalk analysis, in which I have all the data points and polylines for the sidewalks. But I am attempting, to attribute these lines with colours and condition grades. Example: http://vanderhawk.net/wp-content/uploads/2011/02/Rancho_SW_Priority_Rank.jpg What tool would I need to use to do something like this? Thanks!!
Thanks for the reply Dan!
I am working on this school project with Alex and we collected the data to characterize the sidewalks. We collected points for every 3-5 meters and as you mentioned we would like to assign those observations to the edge of the closest sidewalk polyline, so we can represent our data as line features.
Sidewalk lines are one line for each side of the block and there are only two vertices for each sidewalk feature, therefore split line at vertices tool wouldn't be able to do the trick. Is there any other tool we can use? We are considering creating lines manually. I am attaching a screenshot below; each sidewalk feature is shown in different color. Green points represent sidewalks with no cracking, and red ones are with cracking. I am also attaching a identify window screenshot from one of our points.
Cheers
depending upon the actual network, you could look at densifying the lines if needed, or perhaps simply split the lines at vertices may be sufficient Split Line At Vertices—Help | ArcGIS for Desktop
It is just if you have point data, containing the observations and values, they should apply to the segment closest to them and you don't want 5 points joined to one segment. so have a look at the data itself...did one point get collected to represent 10m, 100m 1000m? The points must have been collected for a reason... perhaps to characterize the nature of the sidewalk in that area ... one would surmise
What if the sidewalk polyline is not very well partitioned?
What would be an ideal length for partitioning a long sidewalk line into? Is there a way to automatically partition a lengthy line other than the "production editing" tools?
assuming you have a well partitioned sidewalk fine providing of a good level of segregation, you could use a spatial join of the points to the polyline to bring any of those attributes over, then save the result so that you can symbolize the polyline file according to the classes or attributes that you wish to show.
