Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Online
Specify scale on PrintTemplate
NickKouloungis
I would like the ability to specify a map scale for printTemplate outputs in the ArcGIS Javascript API. I am primarily using the new Finder app deployed on my web server which references an AGOL webmap. The ability to specify a map scale exists within the default print widget in the Flex API and I would like to see this functionality extended to the Javascript API.
Vind meer berichten getagd met
Closed
Status: Closed
Reacties
FC_Basson
Esri will need to extend the printTemplate class so that you can set the "mapOptions" parameters. See this link
http://resources.arcgis.com/en/help/rest/apiref/exportwebmap_spec.html
. If you can construct the
Web_Map_as_JSON
for the print task manually, you can specify the scale.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
