Please add a method to the Attribute Assiant to have a field calculate the 1k USNG number
If you are selecting a point based on the map; what are you only doing a centroid of a 1k Poly? The full calculated location should be able to be returned.
Exactly what I was thinking....
Hi Michael Dawson. Can't you just set up the Intersecting Feature method with the USNG 1k polygon layer as the Input in the Value Info? Intersecting features - Attribute Assistant | ArcGIS Solutions
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
