Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Online
Attribute Field Thousands Separator Default Set to Off instead of On
pbrooks
I find that I have to go into each field to turn off the thousands separator for attributes such as zip codes and FIPS codes for the state and county. I think that if the default was set to turn the thousands separator to "off" instead of "on", then I would not need to visit each and every field to turn the separator off. The same issue comes up with decimal places as well (record numbers, area) Is there another way to change this default that I am overlooking?
Vind meer berichten getagd met
Status: Openen
Reacties
IngmarAlbinson
These setting should follow regional settings on your computer (Control panel - Regional settings).
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
