Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Web AppBuilder
Show Results from Query Widget in Attribute Table Widget (Web App builder widgets)
DavidWhite2
ArcGIS Online Web App builder offers a query widget to select by attributes. The query widget offers the option of displaying the results as an operational layer on the map. The enhancement would be to make this "operational layer" available to the attribute table widget. The attribute table widget appears only to support interactive selections at this time. Having the query results visible in the attribute table widget would allow a user to view, sort and export the records they have already selected via the query widget. The attribute table widget appears to only allow one to filter by extent, and to select rows interactively.
Vind meer berichten getagd met
Status: Openen
Reacties
StanMcShinsky
When you make a selection using the Query tool you can check the box to make the result an operational layer. When that happens it adds the query result to the Layer List widget. There is a drop down arrow to the right of the layer name that onece clicked you can select to "Open Attribute Table". You can open the results in the attribute table and work from there.
PatrickMcColley
Great Idea
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
