Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Ontwikkelaars
Developers - General
Label Segment Dimensions Poly/line Javascript API
JakeGalyon
I think the ability to label each segment of a line, poly, plus getting the total measurement should be implmented into the ArcGIS for javascript API. I contacted tech support about this and this was there suggestion.
Our old arcims site did this, but i'm not a developer so i'm not for sure on how that worked. So our users went from being able to do this with arcims site, and then when we moved onto our custom application written in javascript they are unable to label segments when using measurement tools.
I understand this is possilbe in flex or silverlight.
Vind meer berichten getagd met
Status: Openen
Reacties
AngelaVanderPas2
This functionality is availble in arcreader within a published map.
I have users that are going back to an outdated arcreader map because of the lack of functionality in the measure tool.
This link is to a great widget if it could be add as a choice in the widgets for measuring.
http://gis.yakimawa.gov/cityflex/index.html?config=measure.xml
Am trying to avoid serving maps from my webserver.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
