Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Web AppBuilder
Web AppBuilder Search/Geocoder widget
AdamGebhart
The Search widget that replaced the Geocoder widget in Web AppBuilde (1.2) has been great. However, I would like to know if the following enhancements can be made to the widget and/or the ability of the developer to configure the widget.
1) Allow the Popup or InfoWindow to be moved around by the user.
2) Allow configuring of the Popup or InfoWindow in AGOL
and
WAB, not just AGOL.
3) Allow customizing of the search results (map) symbology. As of now it doesn't appear to be possible in the widget's CSS or configurable in the widget setup. It has to be done through adding code to apps\#\widgets\Search\widget.js and apps\#\configs\Search\config_Search.json. A special thanks to Robert Scheitlin for help with that.
4) Allow more than one field to be displayed in the results list. Maybe limit it to two or three and have the option to show more than one field be configured in the setup just like one can select fields on which the widget searches? And, have the results display be configurable so text can be added or symbols inserted between field names?
Thanks to the WAB for all of their hard work and continued improvement of WAB.
Vind meer berichten getagd met
Status: Openen
Reacties
JeffGarland_AGOL
Can I add to this list the ability to control what coordinate system for entering in a coordinate pair to search on. Not sure to start another idea or if you could add to this one. The enhanced locate widget that Robert S. provides would be a good template.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
