Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Online
Show popup windows based on attribute value in AGOnline:
KirstineRokholm_Jensen
When allowing and configuring pop-ups for a layer, it should be an option to sort the windows based on an attribute value.
E.g. if the certain service-layer contains a Year-attribute, it should be able to see 2015 in the first window, and the year before last in the next window and so on.
In the current version the sorting is not consistent, and so records from 2008 might be visual before 2014 records.
I has no effect to load the services as seperate layers and changing the drawing order - the same records are "on top"/in the first popup window.
Vind meer berichten getagd met
Status: Openen
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
