Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Pro
ArcGIS Pro Ideas
Tasks - Easy way to set layer as only selectable, visible, editable etc
WendyKallio
Provide an easy way to set a layer as the only selectable, visible, editable etc that doesn’t require config update if your TOC changes. This would make it easier to configure but also more tolerant if end user adds other data.
Ex. where you want to run commands that require a single layer be selected in the TOC or where you want to perform a certain type of edit on a layer.
Vind meer berichten getagd met
Tasks
In Product Plan
Status: In Product Plan
Reacties
AmirBar-Maor
Task designer allow to specify and make a layer the only visible / selectable .. etc.
The requirement is to keep this setting even if new layers are being added to the table of content that were not present during the task design time.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
